MADRIX Forum • Requirements for computer - running Key DVI
Posted: Thu Aug 18, 2016 2:40 pm
by Regnar
Hello
Another question...
What will be an optimal configuration for a computer if i will be using Madrix KEY dvi (307.200 pixel) ?
Can i use i5,i7 or do i need to use Xeon processor ?
Regards
Regnar Rabe
Re: Requirements for computer - running Key DVI
Posted: Tue Aug 23, 2016 3:14 pm
Hello Regnar,
When you want to output the full resolution of a MADRIX KEY dvi I would recommend to use a PC with a intel i7 CPU at least with 4 cores (8 threads). Every core of the CPU should have at least 3.6 GHz.
Under the following link you will find the system requirements of MADRIX. The "Example 3" would be a good one for your project:
http://help.madrix.com/m3/html/madrix/i ... ments.html
