Color Presets
Posted: Mon Mar 25, 2019 9:06 pm
by Willy
Hi Dears,
I would be very nice to have a kind of color preset pool. Something allowing the programmer to store a color in a empty slot below the color picker for example.
So that, it would be possible to use that precise color as wanted in a new layer.
And if we change the settings of a "custom color slot", it would of course update the color in the layer referencing to that color.
Best regards and thank you for all the work you already did to improve this amazing software !
Willy
Re: Color Presets
Posted: Thu Mar 28, 2019 10:16 am
Hi Willy,
Thank you for this suggestion!
You are right – this is currently not available in this way.
However, you have the possibility to improve your workflow with a number of options the software currently provides:
– Copy And Paste (via context menu or drag and drop)
– Saving/loading a MADRIX Color Table file (via controls / partially via context menu / via file drag and drop)
The majority of effects are using Color Tables or Color Gradients where all of the above work great. You can learn more about these techniques here:
http://help.madrix.com/m5/html/madrix/h ... ction.html
Thank you very much!
Re: Color Presets
Posted: Thu Mar 28, 2019 7:10 pm
by Willy
Thank you Fritzsche for your answer !
saving/loading color table is indeed a great tool that i'm using a lot
when you are programming, it is not a problem to copy/paste the color as you build new cues.
I'm rather looking forward to a way of updating quickly a lot of layer referencing to a precise color.
I work a lot for TV or Film and even for a white effect, DOP's often asked me to tune the white or another color to match the camera - of course at the last minute before shooting and for all effects
thank you for your attention
Best regards
Willy
Re: Color Presets
Posted: Fri Mar 29, 2019 9:38 am
Okay, thank you! Now, I understand.
It would be like global document colors that update throughout the project.
It is like the concept of Symbols/Smart Objects/Styles in graphic design.
Thanks.
Re: Color Presets
Posted: Fri May 20, 2022 10:38 am
by andyesl
Hi Willy,
a bit of a late reply, but for "white balance" you can use the Filter color picker in the Output pane.
Andy
Re: Color Presets
Posted: Sun May 14, 2023 4:00 am
by MTX-Lightning
With next Version Update (5.6) released in a few weeks there is a new feature "global colors" where you can switch colors dynamically or via DMX. It's really great. It was introduced at the Prolight & Sound in Germany some weeks ago.
