MADRIX Forum • Switch from RGB to GRB lighting
Posted: Sat Dec 04, 2021 3:01 pm
by johntillman045
Hi everyone!
Recently I've created a patch with RGB lights, but it turned out that they were simply GRB lights in the end. Is it possible to simply adjust the light forms to something else, or do I have to redraw everything?
Thanks so much!
Re: Switch from RGB to GRB lighting
Posted: Mon Dec 06, 2021 2:53 pm
by Schulze
Hi johntillman045,
Welcome to the MADRIX Forum!
You will two different options:
1) Using a 'Main Output Filter', in that case the so-called 'Color Swap' filter.
2) By changing the color order for the used RGB Fixture with the 'Fixture Editor'. After changing the Fixture in the Fixture Editor, open the 'Patch Editor' and select 'File' > 'Update Fixture From Library'.
Here you will find more information about Filters in MADRIX 5:
https://help.madrix.com/m5/html/madrix/ ... lters.html
Here you can learn how to apply changes to Fixture Profiles with the MADRIX 5 Fixture Editor:
https://help.madrix.com/tutorials/m5/HT ... _a_pa.html
https://help.madrix.com/m5/html/fixture ... index.html
I hope this helps you!
