MADRIX Forum • how to connect with Wysiwyg R44 in Madrix5
Posted: Thu Jul 25, 2024 8:52 am
by Thavie
Hi all,
I want to know how to connect with Wysiwyg R44 in Madrix5
is that possible ?
Re: how to connect with Wysiwyg R44 in Madrix5
Posted: Thu Jul 25, 2024 9:52 am
by Schulze
Hello Thavie,
Yes, this is possible.
Please perform the steps below:
On the MADRIX 5 side:
1) Select "Preferences" > "Options...".
2) In the "Devices Network" tab, activate sACN and select your own IP from the list (MADRIX is the sender).
On the WYSIWYG side:
1) Run WYSIWYG and start a new file.
2) Insert a venue, some hang structures, and fixtures.
3) Patch the fixtures to one or more sACN Patch Universes.
4) Switch to LIVE mode.
5) From the Live menu, select Device Manager.
6) In the Device Manager window, click New.
7) In the Library Selection window, search for sACN (note spelling).
8 ) Select the single search result and click Insert.
9) With sACN selected in the device list, click Properties.
10) Bind the Universes that you created to the incoming sACN ports.
11) When the binding is complete, click OK.
12) In the Device Manager window, with sACN selected in the device list, click Connect.
13) Close the Device Manager window.
Result: You are now connected to sACN and WYSIWYG will begin reacting to incoming sACN data.
You can also find the steps above in the WYSIWYG manual.
