MADRIX Forum • MADRIX Aura 12 Not Recording Over Network or USB
Posted: Wed Sep 24, 2025 3:08 pm
by lughscape
Dear Support Team,
I am experiencing an issue with my MADRIX Aura 12 device. The unit is unable to record scenes either via the network (LAN) or via USB connection.
Details of the issue:
Device: MADRIX Aura 12
Connection Methods Tested: Network (LAN) and USB
Problem: Recording does not start over network and USB only possible by manual
Notes: I have confirmed power supply and basic connectivity, but the recording function still does not work.
Could you please advise on possible causes and troubleshooting steps? Additionally, are there any specific firmware or configuration requirements I should check for proper recording?
Thank you for your support.
Best regard,
Dohyun Kim
Re: MADRIX Aura 12 Not Recording Over Network or USB
Posted: Wed Sep 24, 2025 3:49 pm
by Schulze
Hi Dohyun Kim,
Do you use MADRIX 5 to record the scenes? If you use MADRIX 5, please make sure to activate the "inoage - MADRIX" checkbox in the "Options" dialog ("Preferences > Options...").
Did you define a static IP address for your computer (such as 10.0.0.1 and subnet 255.0.0.0)?
The USB connection only works for firmwareupdates and power supply.
Posted: Thu Sep 25, 2025 2:43 am
by lughscape
Thank you for your reply.
I have already configured a static IP address on my computer (10.0.0.1 / 255.0.0.0) and set the AURA device accordingly. I also activated the "inoage – MADRIX" checkbox in the Preferences > Options dialog as you advised.
However, the recording is still not working.
For your reference, I am attaching the screenshots of my current settings.
Could you please check the attached configuration and advise me if there is anything I might have missed?
Best regards,
Dohyun Kim
Posted: Thu Sep 25, 2025 8:28 am
by Schulze
Hi Dohyun Kim,
Thank you for the screenshots.
Please send us your MADRIX 5 setup and a logfile to info[at]madrix[dot]com. To save the logfile please start MADRIX and select "Tools" > "Logfile...", click the button "Save As..." and enter a name for the logfile.
Thanks in advance!
Posted: Sun Oct 12, 2025 2:20 am
by lughscape
I believe I’ve found the cause of the recording issue. It appears that Wi-Fi was enabled, which interfered with the process. After turning off Wi-Fi, everything worked properly.
Thank you very much for your help and guidance.
