Midi Learn
Posted: Sat Oct 08, 2011 8:34 pm
by mission_rave
The biggest feature i think is also not too difficult is to have Midi learn.. It will make life very simple..
And can i request for a Map file for APC 20 ?
thx
bunty
Re: Midi Learn
Posted: Mon Oct 10, 2011 9:55 am
by Wissmann
Inside the Device Manager at the Midi Tab you can select the midi devices and which kind of ptotokol to use.
Also you are able to edit the protocol with the midi remote editor.
Inside this Editor you have a Assign Button.
With this Button active MADRIX gets the dmx signal (midi learn) if you move a midi slider or hit a midi button.
Regarding APC20 we will provide a map if we get a device into our hands here in the office.
Re: Midi Learn
Posted: Wed Nov 20, 2013 4:15 pm
by vj
something new with the map file for apc 20 ??
it works preety good with the apc 40 map but i don't have the crosfader
Re: Midi Learn
Posted: Thu Nov 21, 2013 10:55 am
Hello vj,
Sorry, but we haven't had a test unit here in the office. Have you tried to customize the APC40 map to match your APC20? You can use the built-in MADRIX MIDI Remote Editor and setup up the crossfader according to your requirements!
Thanks.
