MADRIX Forum • american dj flash panel 16 rgb 48
Posted: Wed Dec 21, 2011 4:57 pm
by surky
i have american dj flash panel 16 rgb 48....
for example: i have 20 panell this is 5x4 they are 2 dmx universe and problem is that is repeated on panel...if i klik with mouse on first panel c1u1 is flashing c1u2..... what i must do that ist not repeated!! thankyu!
Re: american dj flash panel 16 rgb 48
Posted: Fri Dec 30, 2011 2:44 pm
by jaekel
Step 1:
adressing your panel for the DMX channels. For first LINE.
Set the first panel to CHANNEL 1, the second panel to CHANNEL 49, the third panel to CHANNEL 97, ......
And in the second LINE do the self.
Now you have two LINEs. The first LINE is UNIVERSE 1 and the second LINE ist Universe 2.
Step 2:
Make in MADRIX with the MatrixGenerator (press F2) your patch. Select
protocol: DMX
Fixture: American DJ Flash Panel 4x4 48ch RGB
Rotation: original
Count X: 5 Y: 4
Start Corner: Top Left
Main Orientation: Horizontal
Snake Mode: Check
With Fixture Rotation: UnCheck
DMX Start Channel: 1
DMX Start Universe: 1
see picture
Step 3:
In DeviceManger of MADRIX (press F4)
you can activated your DMX interface with check box ENABLE. And you can set the interfaces to Universe 1 and Universe 2.
activate your DMX interface and select used universe.
see picture, i have simulate this with other interface
Step 4:
Select the SCE ColorRamp Effect, set it to diagonal direction and check your output screen.
see picture
I hope its running with this example.
