DMX Device Manager not remembering universe settings.
Posted: Tue Jul 30, 2013 10:19 pm
I give up. I've tried 4 times now to set Madrix's DMX device settings to match the DMX universes and ACN settings used in my system.
As I go through the 14 universes I'm using one by one, I can see that Madrix is communicating with my gear, and by the time I get to the end, all the universes are lit correctly and responding as I would expect them to.
So far, so good. Having set the device settings where I want them, I save them as a .mdmxx file using the "save the device settings as..." button in the lower left hand corner of the window (I've also tried exporting the settings from the File menu, with the same result).
When I quit Madrix and then restart the program, the device settings go back to their default settings (DMX universes 1...XX, ACN universes 1...XX).
I try reloading the .mdmxx settings file I've just created before shutting down the program...and the program loads the file with default settings.
Either the .mdmxx file is not being saved properly, or Madrix is not loading it correctly.
