MADRIX Forum • DMX-IN and HTP, how does it work? - Page 2
Page 2 of 2
Re: DMX-IN and HTP, how does it work?
Posted: Wed Aug 08, 2012 10:03 am
I have tried to answer the NEO issue above: The message says that you are using more fixtures than your NEO has the license for (15 Universes compared to 1 Universe license). If you are certain that is not the case, simply dismiss the message. It may be just outdated.
And yes, the HTP issue is a bug. It is not just with the NEO, it is with the MADRIX software.
A fix can take quite a while (weeks/months) since a full software update needs to be released.
Please let us know if you would need an urgent fix. Thank you!
Posted: Sat Aug 11, 2012 12:55 am
by newton2013
I'd love an urgent fix. Is there an earlier version that does not seem to show the bug? I have no problem using an earlier version. I thought I would have been using your software months ago, it took me awhile to get online to ask about it, I was sure it was a mistake on my end- human error. As it stands I am kinda just waiting in limbo. I have empathy for you guys as obviously this was an unforeseen error. I will bend over backwards to help find a solution. Basically, I have had to tell my clients that I have overstated my abilities.
Posted: Mon Aug 13, 2012 10:46 am
Oh, that's really not good!
We will try to come up with a quick solution and I will keep you updated!
Meanwhile, you might want to test MADRIX 2.11. I ran a quick test and it seems to be working as you would require in your case. But we are somewhat hesitant to really recommend it. Here is why:
- A lot of bugfixes have been implemented since then. This version might have its own issues.
- A lot of new features and improvements have been implemented since then.
- This version cannot use your current Setup File. You would need to create a new show.
- You would probably have to create the fixture again (make sure to backup your current madrix.mfl file!)
... Or I can help you with the new show file and fixture profiles.
If you want to download it, please use this link: http://www.madrix.com/download/MADRIX_F ... l_2_11.exe
Posted: Tue Aug 14, 2012 10:11 pm
by newton2013
Ahha! Thank you so much. MADRIX 2.11 is working for me.
This will work great, as I can continue programming my shows in my dmxsoftware to trigger MADRIX and later update to the new version when it comes out. I know I will have to do some rebuilding/programming then, but that is no problem. I can also do my client demos now. No bugs are getting in my way as of now. You have saved my butt, THANKS!
:D
Posted: Tue Oct 23, 2012 3:31 pm
by newton2013
Curious if this issue is being addressed in the next update, and when that may be available. Thanks so much!
Posted: Wed Oct 24, 2012 9:45 am
Yes, the next update will definitively address this issue! Unfortunately, we have no release date yet. I'll update this topic once that changes. Thank you!
Posted: Tue Dec 11, 2012 3:15 pm
Hello newton,
Thank you for your patience!
We have just released MADRIX 2.14b which should fix the issue.
Posted: Sat May 04, 2013 1:08 am
by newton2013
Worked Great for awhile.
I built a new computer to run my shows,
Worked like a charm until I uninstalled a networking USB dongle.
Now I cannot get Art-net to come thru.
I know it's human error, so I spent hours and hours here and there trying everything I can think of.
Here is a log dump...
It sees DMXCONTROL, but will not let it flow through... it used to...
293 2013/05/03 18:55:11 Art-Net Warning receive 0x2100 OpPollReply from 169.254.96.229 (myself machine)
294 2013/05/03 18:55:11 Art-Net Info receive 0x2100 OpPollReply from 169.254.96.229
295 2013/05/03 18:55:11 Art-Net Warning Found ArtNet node without valid MAC address. IP: 169.254.96.229 UseBroadcast=No MAC:00:00:00:00:00:00, SubNet:0x00, PortCount:1 Port1(In=Y Out=Y UnivIn=0/0x00 UnivOut=0/0x00 Frame=optimized) Id:3848339113,StyleCode:server,Firmware 0.14, active device 0, esta:SK-Software manufacture:DMXControl product:DMXControl SubId:0, Root-Ip:0.0.0.0, Status2:0x00, Product don't supports web browser configuration, IP is manually configured, Node is not DHCP capable, Node support 15Bit Port-Address (Art-Net 3)
296 2013/05/03 18:55:11 Art-Net Warning Found ArtNet node without valid IP address in PollReply packages, use ip from OSI layer 3. IP: 169.254.96.229 UseBroadcast=No MAC:00:00:00:00:00:00, SubNet:0x00, PortCount:1 Port1(In=Y Out=Y UnivIn=0/0x00 UnivOut=0/0x00 Frame=optimized) Id:3848339113,StyleCode:server,Firmware 0.14, active device 0, esta:SK-Software manufacture:DMXControl product:DMXControl SubId:0, Root-Ip:0.0.0.0, Status2:0x00, Product don't supports web browser configuration, IP is manually configured, Node is not DHCP capable, Node support 15Bit Port-Address (Art-Net 3)
297 2013/05/03 18:55:11 Art-Net Info node found IP: 169.254.96.229 UseBroadcast=No MAC:00:00:00:00:00:00, SubNet:0x00, PortCount:1 Port1(In=Y Out=Y UnivIn=0/0x00 UnivOut=0/0x00 Frame=optimized) Id:3848339113,StyleCode:server,Firmware 0.14, active device 1, esta:SK-Software manufacture:DMXControl product:DMXControl SubId:0, Root-Ip:0.0.0.0, Status2:0x00, Product don't supports web browser configuration, IP is manually configured, Node is not DHCP capable, Node support 15Bit Port-Address (Art-Net 3)
298 2013/05/03 18:55:16 Art-Net Warning receive 0x2100 OpPollReply from 169.254.96.229 (myself machine)
299 2013/05/03 18:55:16 Art-Net Info receive 0x2100 OpPollReply from 169.254.96.229
300 2013/05/03 18:55:16 Art-Net Warning Found ArtNet node without valid MAC address. IP: 169.254.96.229 UseBroadcast=No MAC:00:00:00:00:00:00, SubNet:0x00, PortCount:1 Port1(In=Y Out=Y UnivIn=0/0x00 UnivOut=0/0x00 Frame=optimized) Id:3848339113,StyleCode:server,Firmware 0.14, active device 1, esta:SK-Software manufacture:DMXControl product:DMXControl SubId:0, Root-Ip:0.0.0.0, Status2:0x00, Product don't supports web browser configuration, IP is manually configured, Node is not DHCP capable, Node support 15Bit Port-Address (Art-Net 3)
301 2013/05/03 18:55:16 Art-Net Warning Found ArtNet node without valid IP address in PollReply packages, use ip from OSI layer 3. IP: 169.254.96.229 UseBroadcast=No MAC:00:00:00:00:00:00, SubNet:0x00, PortCount:1 Port1(In=Y Out=Y UnivIn=0/0x00 UnivOut=0/0x00 Frame=optimized) Id:3848339113,StyleCode:server,Firmware 0.14, active device 1, esta:SK-Software manufacture:DMXControl product:DMXControl SubId:0, Root-Ip:0.0.0.0, Status2:0x00, Product don't supports web browser configuration, IP is manually configured, Node is not DHCP capable, Node support 15Bit Port-Address (Art-Net 3)
302 2013/05/03 18:55:16 Art-Net Info node updated IP: 169.254.96.229 UseBroadcast=No MAC:00:00:00:00:00:00, SubNet:0x00, PortCount:1 Port1(In=Y Out=Y UnivIn=0/0x00 UnivOut=0/0x00 Frame=optimized) Id:3848339113,StyleCode:server,Firmware 0.14, active device 1, esta:SK-Software manufacture:DMXControl product:DMXControl SubId:0, Root-Ip:0.0.0.0, Status2:0x00, Product don't supports web browser configuration, IP is manually configured, Node is not DHCP capable, Node support 15Bit Port-Address (Art-Net 3)
303 2013/05/03 18:55:17 Art-Net Info send OpPoll 0x2000 from IP: 99.63.93.207
304 2013/05/03 18:55:17 Art-Net Info send OpPoll 0x2000 from IP: 169.254.255.255
305 2013/05/03 18:55:17 Art-Net Info receive 0x2000 OpPoll from 169.254.96.229
306 2013/05/03 18:55:17 Art-Net Info send OpPollReply 0x2100 from 169.254.96.229 to network 169.254.255.255
307 2013/05/03 18:55:17 Art-Net Info receive 0x2100 OpPollReply from 169.254.96.229 (myself)
