PLEXUS - using switches to fire different scense
I am struggling to get my PLEXUS to work on the expansion port.
I have tried all the things in the manual - but still I cannot get it to work.
can you please help
Angus
can you please help
Angus
Re: PLEXUS - using switches to fire different scense
Hello Angus,
Can you please explain a little bit what you try to do with the extension port of the MADRIX PLEXUS? Do you want it to use it for input or output?
I want to use it as an INPUT port.
I have the PLEXUS to control the different scenes.
I have a PLC that is going to send a signal to the PLEXUS to trigger different scenes.
I just do not know how to do this or what settings for the plexus.
Thank you
Thank you
The extension port features 15 individual ports as shown here: http://help.madrix.com/m3/html/plexus/h ... _port.html
Only 6 of the ports are available for analog input (0-100%), while all 10 ports can be used for digital input (0/1, On/Off). 5 of the ports are for power/ground.
In order to configure your PLEXUS, please use the menu "Tools > PLEXUS Configuration...".
When creating a PLEXUS Configuration, a show file to put on the SD card, you then need to make sure to configure the > tab "Extension Ports" as well.
Learn more: http://help.madrix.com/m3/html/plexus/h ... confi.html
There you can define what each of the 10 ports should do.
For example: #1 could be defined as Type - Digital Input, Action - Scene, Value - 1. That means if the PLEXUS receives a digital signal on Port 1 (which physically is Pin 2), it will trigger Scene 1.
If I have a physical switch - can you tell me the exact settings I should have.
I have tried a variety and had no luck.
If it is a simple push button switch that closes the circuit momentarily - how would I set this in the PLEXUS config.
I really appreciate your assistance.
Angus
Angus
Hi Angus,
Can you please send us your PLEXUS Configuration to info[at]madrix.com?
Please add a description of the physical switch you are using and which Scene should be triggered.
Thank you for your help!
In order to configure your PLEXUS, please use the menu "Tools > PLEXUS Configuration...". .
When creating a PLEXUS Configuration, a show file to put on the SD card, you then need to make sure to configure the > tab "Extension Ports" as well. ??
_______________
We offer guaranteed success for Testking cissp certification exam with help of latest pmp certification certification and jhu practice questions and the exams of Tabor College
_______________
Hello chalshokhi,
Do you need any assistance from us?
