Timecode
Sheik954
Timecode
Post by Sheik954 »
I had made a cue list with 178 cues. The first cue was to start at 9am. And each cue has a 6frame duration. It worked perfectly well for me. A day later it is not working correctly. The cue keeps activating even when it's not time for it yet. And it keeps getting stuck from cue 1 to 2 to 1. It's just not working as it is supposed to. Just sent the working file to info@madrix.com for advice. Any takes on this?
Re: Timecode
Thank you for sending the file! I can confirm that we received it and will get back to you via e-mail on this matter. Thank you very much!
