madrix generator
hazan
madrix generator
Post by hazan »
hi all
Im very new with this software and im sure its amazing.
I need some help how to config in the madrix generator my line up.
I have 126 led tubes 64led each and 16 pixels its for show room.
I will make it in 18x7 cube can some one plz help me just to conig it in the madrix generator..
im use the last version of madrix software.
Best Wish
Re: madrix generator
Hi Hazan,
Welcome!
Every LED installation is different. That is why it won't be easy to tell you the exact settings of the Matrix Generator for your project.
It also depends on the products you are using and the way you are going to connect the tubes and hang them in your location.
Can you please let us know which exact tubes you are going to use? Are they controlled via DMX or DVI?
Please have a look at the user guide as I am sure it will bring you closer to your goal.
http://help.madrix.com/m3/html/madrix/h ... rator.html
Thanks. We are looking forward to hearing from you!
hazan
Post by hazan »
hi there.
this is the tubes I will use 1m tube,64pcs smd rgb 5050 on double side,16pixels
and yes I will use DMX control
I will put it in the celling like in this picture.
in the picture you can see 2 cubes but the installation is 1 cube.
and tnx for the link I will try my best.
Best Wish
Hello hazan,
When you want to create a Patch with the MADRIX Generator in MADRIX have also a look the following tutorial links. In this tutorials you can also learn step by step how you can create the desired patch in an easy way.
http://help.madrix.com/tutorials/html/i ... rator.html
