Mapping save function as Lightdesk
spacecremers
Post by spacecremers »
It would be great if you can save a mapping for a layer, and always be able to load this. The other advantage is, if the patch is changed, you only have to change one mapping. The others layers change the same way!
Re: Mapping save function as Lightdesk
Hello spacecremers,
Thank you for the input.
With the release of MADRIX 3.3 RC you will be able to copy the desired Map and paste it to an effect on an other layer or storage place in MADRIX.
To use the copy and paste option please click with the right mouse button on the "Map" button in MADRIX and a popup menu opens.
