Audio program that will listen to Madrix Time Code Sender?
LiteKnight
Post by LiteKnight »
Hello.
I've just programmed a show to music.
The MADRIX cues are using timecode, and I'm running them off of the Madrix Time Code Sender.
What I am looking for is an audio playback program that will receive the Time Code being sent by Madrix's Code Sender, and playback my audio files at a certain time code.
Does anyone know of a software that has this functionality?
Re: Audio program that will listen to Madrix Time Code Sende
Maybe the other way round could be useful. Have you seen this thread?
http://www.madrix.com/en/home/forum/vie ... 15/t,1047/
LiteKnight
Thank you,
It wasn't perfect, but it got the job done.
I'd prefer a program that lets you scrub the audio with timecode, it would have made the programming easier, but the price was right.
Scott
withapict
Post by withapict »
I am going the other way around. I programmed this in Light Show Pro but looking to combine with Light show pro and Madrix
https://www.14dd5266c70789bdc806364df4586335-gdprlock/watch?v=KZM-8T6Ct1k
I would like to run a show I export from Light Show pro and I can easily export data and run from an SD card. Im looking to send some sort of trigger data to cue madrix on occasion to some elements.
Hi withapict,
When you want to trigger MADRIX, you have quite some options to choose from, such as DMX-IN, Art-Net Remote, and more!
Learn all the details here:
http://help.madrix.com/m3/html/madrix/i ... ntrol.html
Does that help?
withapict
Post by withapict »
Yes that's a good start. Not workin yet but better ideas there.
