CITP to grandMA onpc
cg
Post by cg »
I want to have Madrix and grandMA2 onPC running on the same PC and control Madrix by CITP from grandMA. Did anyone ever try that, is that possible?
I have a MA 2portNode, so the onPC does output DMX and ArtNet. It's just that the network configuration seems a little bit weird...
thanks for any hints!
cg
Re: CITP to grandMA onpc
Post by cg »
...further on: remote control of Madrix from grandMA2 onpc using ArtNet (on the same PC) is working.
Now it's just that Madrix does not show up in the CITP dialog of grandMA.
Hello cg,
When you want to send CITP data between MADRIX and the grandMA onPC and both programms are running on the same machine it is necessary to use 2 network cards which are working in the same IP-Address range but with different IP-Addreses. Also you have to connect the 2 network cards togehter for instance with the help of a switch.
