Remote Control cuelist
Klanook
Post by Klanook »
Hi all,
Is there a way to change the cuelist goto cue number (function 26 in the 26 ch profile) to 16bit in the remote profile, as I have exceeded the number of cues that I can trigger via light factory.
My cuelist is approx 280 long and I would like to be able to use the goto cue #.
I'm using the 26ch profile.
Cheers.
Michael
Re: Remote Control cuelist
Hello Klanook,
Thank you for this hint.
At the moment it is not possible in MADRIX to go directly to a cue in the "Cue List" wich is greater than 255.
But if you want you can explain what you want to do or send us your MADRIX setup to info[at]madrix[dot]com. Maybe there is a workaround to get the desired result.
Klanook
Post by Klanook »
Hi Guertler,
Its something that would be good to have for June next year. Not urgent this at the moment as the current show has already started. We ended up dropping cues/shifting stuff around and calling discrete storage places - not as user-friendly as using the cue list though.
The idea was that each song in the show would have a discrete cue number at the start of the song. After that each cue in the song would be triggered by "Cue Go"
This would enable us to add extra cues into a song as needed. We would then just have to update the first cue number for the songs after that.
Hello Klanook,
What you can do in your case:
Add the first cues of each song to the top of the Cue List and work with "Follow Cues".
So you have the possibility to start cues and a automatic run through of the desired cues for 256 songs.
When you send me a mail to info[at]madrix[dot]com I can send you a little sample MADRIX setup.
