Web Safe SetTickerText
poya
Post by poya »
Hi Guys,
I've almost finished my project and the last stumbling block I'm having is sending web safe strings for the ticker text to display.
Using setTickerText HTTP command, the '#' or %23 equivalent is being dropped from the string. so the message 'Welcome to #HelloWorld testing' becomes 'Welcome to' when sent via the setTickerText HTTP command. Is there a way for me to ensure all characters sent are correctly interpreted by Madrix?
Thanks in advance for your help so far, been a huge help.
Poya
Re: Web Safe SetTickerText
Hello poya,
At the moment the MADRIX HTTP server can not interpret the # or %23 and also discards all letters which are behind this sign.
What you can do is: Change # to another string of signs like +++ before the application sends the string to the MADRIX.
In MADRIX you have to create a "Layer Macro" which replace the ++++ to a #.
Maybe the following macro code snip is helpful:
Code: Select all
string txt;
void InitEffect()
void PreRenderEffect()
	txt = GetText();
	replace(txt, "++++", "#");
	SetText(txt);
poya
Post by poya »
Hey Guertler,
Thanks for that suggestion. I've implemented it into my ticker text using the snippet you provided.
I was just wondering if there are any other major characters I should provide a fall back for; a list of any you know if would be great.
Thanks again.
Poya
Helo poya,
At the moment you can not send the # (%23) and ? (%3F) via HTTP to the "SCE Ticker/Scrolling Text".
poya
Post by poya »
Hey Guertler,
I've pretty much finished doing all I need to do. I have one stumbling block that I don't know how to get around at the moment.
I've got a script replacing certain keywords with the correct character. It all works bar this line
replace(text, "{QUOTE}", " " ");
Now this fails because I can't use single quotations like so
replace(text, "{QUOTE}", ' " ');
and I can't escape it like so either
replace(text, "{QUOTE}", " \" ");
So I'm wondering if there is a way for my to type the " character.
Thanks in advance!
Poya
Hello poya,
At the moment it is not possible to mask a double quote in a string in the MADRIX Script/Macro.
Below you can find a work around how you can solve the problem:
Code: Select all
string doublequotes ="#";  //Because you can not use the " in the macro
                           //we use the # it is next sign after
                          //the " in the ascii table
string singlequotes ="'";
void InitEffect()
	doublequotes[0]= doublequotes[0]-1; // in the ascii table " is before #
	strip(doublequotes); // remove last spaces
	// get ticker text
	string text =GetText();
	// transform ticker text
	replace(text, singlequotes, doublequotes);
	// set ticker text
	SetText(text);
void PostRenderEffect()
void MatrixSizeChanged()
	InitEffect();
