Single channel(mono) LED and RGB LED together
ricovijay
Post by ricovijay »
hi
i want to control single channel LED and RGB (three Channel ) together ..
if add together cant able to control both it means all RGB Channels become White
Please Help me
Re: Single channel(mono) LED and RGB LED together
1)
In MADRIX 3, please open the Patch Editor (menu Preferences > Patch Editor) and a new window will open.
2) Then, go to Edit > Matrix Size... and another small window opens. Make sure that you set Color Depth to 3!. This should solve the issue.
Please let me us if that helps! Thank you!
ricovijay
Post by ricovijay »
Thanks Many :)
ricovijay
Post by ricovijay »
Hi
Is Thr any possible to load cue list remotely ?
regards
vijay
Hello ricovijay,
When you are using a PLEXUS in stand alone mode you can control the trigger to play the next scene or to play a desired scene remotely.
In the following link you can learn how you can control the PLEXUS in stand alone mode remotely.
http://help.madrix.com/m3/html/plexus/i ... ntrol.html
When you want to control the MADRIX Cue List in "Live Mode". That means MADRIX is running and the DMX data will be send via the PLEXUS. You can also use one port of the PLEXUS to control the MADRIX Cue List remotely. In the following link you learn how you can work with the Remote Editor in MADRIX:
http://help.madrix.com/tutorials/html/i ... mx_in.html
