Support for EntTec Open DMX USB (70303)
SFX Group
Post by SFX Group »
Hi all
Does Madrix support the EntTec Open DMX USB adapter?
https://www.enttec.com/?main_menu=Products&pn=70303
As part of my testing i dont want to invest to much money until i know this will all work, the above is cheap and would be nice to test with.
Many Thanks
Ashley
Many Thanks
Ashley
© Copyright 2015 - http://www.ashleygriffin.ca
Re: Support for EntTec Open DMX USB (70303)
Hello Ashley,
Please have a look to the following link:
http://help.madrix.com/m3/html/madrix/i ... faces.html
Here you will find all MADRIX supported interfaces. Under the topic FTDI you will find the "EntTec Open DMX USB" interface.
But you have to know when you are using this interface MADRIX will work in demo mode furthermore and you can use it for testing. To unlock the MADRIX license you will need a MADRIX KEY or a MADRIX DMX interface like the MADRIX NEO.
http://www.madrix.com/en/home/products/neo.html
SFX Group
Post by SFX Group »
Hi
Thanks, thats what i am looking for.
I have to test some lighting, dont want to spend alot of money on the test, but i do want to see the lights work as there designed. Once i know the test works we will be using the EntTec DMX over Ethernet (Art-Net) hardware (71010 and 71011).
We would also get a key for Madrix to work directly with it.
Many Thanks
Guertler wrote:Hello Ashley,
Many Thanks
Ashley
