Splitting up a show to run on multiple Plexus
cinetron
Post by cinetron »
Hi . I am working on a 4 universe installation and want to use a stand alone controller. I am looking into the possibility of using 2 Plexus units. If I design the show in Madrix is there a feature that will split my show in 2 so I can easily use 2 Plexus for this or do I need to manually design the show for 2 separate units? Do you have a tutorial on how to design a show using multiple units? I know I can set up a Master Slave scenario but want a hassle free way to split the show for the 2 devices.
Re: Splitting up a show to run on multiple Plexus
Hi cinetron,
welcome to the MADRIX Forum and sorry for the late reply.
If you set up a show in MADRIX where you patch the fixtures for 4 unsiveres you can create the necessary files for your two PLEXUS devices at one time.
Please follow this instruction:
http://help.madrix.com/m3/html/plexus/index.html
During the conversion MADRIX will use the current patch and create all necessary dxd files you need for aour two PLEXUS devices.
Hi cinetron,
Feel also free to go through the PLEXUS tutorials available here:
http://help.madrix.com/tutorials/html/index.html
