Creating profiles for RGBWA
I have several different LED fixtures I would like to create profiles for that are RGBWA. I have been unsuccessful with finding a work around. Do you have a solution for this? I am also interested to know if you are going to add the Amber in the fixture editor.
Example:
My 12 fixture RGBWA LED bar has a 60 channel mode intended for pixel mapping. In the fixture editor for the 5th channel I set 0-255 at 0. This looks slightly better than using a generic RGBW profile but not by much. I still dont have full color control.
Help!
Thanks,
Ami
- Luma Box Designs -
Example:
Help!
Thanks,
Ami
Re: Creating profiles for RGBWA
Hi Ami,
currently the MADRIX Software only up to 4 channels for Colors, like RGBW or RGBA.
For RGBWA fixtures you have to set up a fixture where only RGBW is controlable by the MADRIX Software and the A channel have to have a fixed value like 0 (Zero).
There is no simple solution to get full Control over all 5 Color channels by MADRIX in the Moment.
