3.4 & 3.4a Freezing in Windows 10
So I'm having some issues with Madrix freezing if I upgrade past 3.3. I'm running Windows 10 with 16GB ram and program on an SSD. I've done reinstallations, clean installs, video card reinstalls, with no luck. Has anyone else ran into this problem?
Thanks in advance.
Thanks in advance.
Re: 3.4 & 3.4a Freezing in Windows 10
Hi dboykin,
i am sorry to hear you have issues with MADRIX.
So far we have no detailed informations about general issues with MADRIX under Windows 10.
Personal i have issues with Windows 10 at all. It seams to be unstable does not matter which application i am running
To have a chance to look more into detail, please provide a MADRIX logfile and the setup you are using and send it to info[a]madrix[dot]com.
For this open the logfile dialog and check the option save permanently.
With this you will get a logfile with informations about MADRIX until it freeze.
Please try to update drivers. Especially the video card driver are the most often reasons for unstable operations.
