CPU load up to 99% by starting Madrix 3.4a
Norman78
Post by Norman78 »
Please help!
CPU load at 90-99% from %1 after starting Madrix.
All 8 Intel CPU Cores at the limit.
Some effects and Videos very slow because of the high CPU load
Where is the problem, What can I do?
Repair-Installation done, but no improvement..
Norman78
Re: CPU load up to 99% by starting Madrix 3.4a
Post by Norman78 »
Hello....here details from yerterday night usning Madrix 3.4a:
Directler after running Madrix on my intel i7 8-Core PC (8GB RAM), all CPU Cores up to 90%, but Madrix work without any problems.
Using build in Madrix Effects also no problem.
But...if i use Video-Files with high frquency flashing effects for Electro Music Beats, after 8-10 minutes the videos getting slower, then the Video freeze, all other DVI and LED-Panels we use also freeze, Madrix freeze. In this situation i have to restart the PC.
If i use slow Videos like dancing girls or slow visual Effects, freezers after 15-20 Minutes.
When i realize the Videos getting slower, i can close the Video-Files, wait 2-3 Minutes, here no freezers or hang up! After closing Video files CPU load down to 70%.
Is this a problem with CPU temperature? A Madrix buffer Problem?
Hi Norman,
i am sorry you are in trouble with MADRIX.
Please provide us the logfile, setup and most important one of the video files which cause the issues you talked about.
Currently ia m not able to tell you if it is about MADRIX or your computer hardware.
If you send us the files we will have a better chance to figure out what goes wrong.
Please send to info[at]madrix[dot]com.
