V3.5a crash with peperoni
cg
Post by cg »
I just wanted to update from 3.4a to 3.5a and had to find out that it does not work...
After spending some time it seems to be the Peperoni interface that keeps V3.5a from starting. (in this case a Rodin2)
If I reset Madrix to default settings, it starts and works normally. As soon as I enable the Peperoni interface, next start will somehow crash Madrix, the logo does not disappear and the program window does not completely load although the menu somehow works. The Peperoni interface does not appear in Madrix device manager. I will send error logs by mail.
Going back to V3.4a works like it did the months before...
Re: V3.5a crash with peperoni
Hello everybody,
This post will also be handled by email.
We will inform you after we found the solution of this problem.
The problem is an incompatible Peperoni interface driver with MADRIX 3.5a.
If anybody else has also a problem with the Peperoni interfaces in connection with MADRIX 3.5 please contact us via email to info[at]madrix[dot]com.
The problem will be fixed in the next release of MADRIX 3.
