Spout
mixalisfr
Spout
Post by mixalisfr »
I would like to ask if madrix have spout integration and if it don;t if it plan to have spout integration thank you
Re: Spout
not yet.
Yes we are interested in of course but have no scedule for it right now.
Ismal
Re: Spout
Post by Ismal »
If you want to input Spout into Madrix, you can by using the SCE Capture effect and choosing SpoutCam, if you have correctly set up a Spout sending device of course.
Re: Spout
Hi Ismal,
thank you for this hint.
We did not know this but we test it and it works great.
mixalisfr
Re: Spout
Post by mixalisfr »
Spoutcam appears to the application as one device.
Spout, Syphon and NDI can have many senders with different names but that isn’t the case for a virtual webcam
Re: Spout
Hello mixalisfr,
The described behavior of MADRIX 3 in connection with the SPOUT virtual camera is based on this virtual camera. MADRIX 3 has only the access to the devices which are provided from the driver.
But with the release of MADRIX 5.1 MADRIX 5 will support SPOUT and NDI support natively and you can capture in MADRIX as much SPOUT or NDI devices as the sender will send.
If you need more than one SPOUT input stream, we recommend to update to MADRIX 5.
mixalisfr
Re: Spout
Post by mixalisfr »
canwe post an icon of madrix with a link to the the product website on the spout website and i would like to know when spout 5.1 will be realised
Re: Spout
MADRIX 5.1 will probably be released within the next two weaks.
hendrawinata
Re: Spout
Post by hendrawinata »
I am wondering if Madrix 5.1 does have SPOUT OUTPUT so instead of capturing, it also sends out effect. Thx
Re: Spout
From the official release notes of MADRIX 5.1
- New Protocol: Added support for sending Spout [Preferences > Device Manager... > DVI Devices].
- New Protocol: Added support for receiving Spout [SCE Capture].
(https://www.madrix.com/products/software/releases)
