Control MADRIX Output via Art-Net
Didda
Post by Didda »
Hi, I follwed the tutorial Remote Control Via Art-Net And CITP (http://help.madrix.com/tutorials/html/index.html) from step 1 to 10 and I can see my dmx input values (from another program on another computer) in the DMX watcher. But I don't want to use the remote options in Step 11. I just want to have the DMX value from the Art-Net Input applied to the belonging RGB Light on the MADRIX output.
For Example DMX Watcher says DMX Adress 1 is 0, 2 is 255 and 3 is 0 and I have a RGB pixel on those adresses it should be green.
I am sure this is very easy, but i cannot get it to work.
Thanks for your help.
Re: Control MADRIX Output via Art-Net
Hello Didda,
Welcome to the MADRIX Forum.
You can pass an Art-Net signal throught MADRIX and display it on your desired fixtures. Therefor you have enable the "Mapping" Option in the "DMX Input" tab of the "Device Manager".
in the following link you can learn how you can work with the "Mapping"
http://help.madrix.com/tutorials/html/i ... adrix.html
Didda
Post by Didda »
Hi, thank you.
I tired this and it hasn't worked.
But the problem was that mapping is not allowed in the Demo Version. This wasn't listed on the Homepage.
Hello Didda,
You can also test the "DMX Mapping" function in MADRIX Demo mode. It will work.
But also in case of "DMX Mapping" MADRIX will interrupt the DMX output every minute if it is running in Demo mode.
