How to drive 3 independent matrix and synchronise?
dvjcodec
Post by dvjcodec »
i have no problems with generate and run simple, one matrix, but how to drive 3 independent martix (2 pcs on walls and one, big piece on ceiling).
My customer wondering to purchase Madrix, but I need to show on demo how it can work :(
Is possible to drive 3 (or more) matrix (total 6000-8000 pixels) and set effects indyvidually on each?
Re: How to drive 3 independent matrix and synchronise?
Hello dvjcodec,
If you want to have different effects on different areas of your patched fixtures you have to work in MADRIX with layers and the mapping.
In your case it means you have to create a patch which includes your 3 areas of fixtures. Now you are able to map the desired effect to one of the created area, add a new layer and create and map the effect for the second area and so on.
Under the following link you can learn how you can work with different areas in MADRIX:
dvjcodec
Post by dvjcodec »
Thank you. I will test soon.
