PC Recommendations
RockitFX
PC Recommendations
Post by RockitFX »
I am going to be controlling an LED installation with a Madrix Professional key. I will be controlling 10,368 pixels, what are the most important factors to consider when choosing a PC?
Re: PC Recommendations
Hello RockitFX,
The most important factor for a MADRIX PC is the CPU.
Under the following link you will find the system requirements for MADRIX:
http://help.madrix.com/m3/html/madrix/i ... ments.html
As you can read in this link the system requirements are depending on different factors. For instance the bigger your desired matrix size the more power of the CPU you will need.
