running Madrix on MAC computer
Regnar
Post by Regnar »
Hello
Can anyone tell me if it´s possible to run the Madrix on a MAC computer ?
regards
Regnar Rabe
Re: running Madrix on MAC computer
Hi Regnar,
The MADRIX 3 software supports the following operating systems:
– Microsoft Windows Vista
– Microsoft Windows 7
– Microsoft Windows 8
– Microsoft Windows 8.1
– Microsoft Windows 10
– Compatible with 32 bit and 64 bit
Mac OS X / macOS are not supported, but you can use a Windows operating system on a Mac computer, for example with the officially supported way by Apple: so-called Bootcamp.
A virtualization software can also help, but usually you won't have access to the full system performance and/or the drivers for certain components, such as the graphics card, might not be as fully developed/compatible.
Thanks.
Regnar
Post by Regnar »
Hello
Thanks, i will try to install windows on my Mac. so i can also use the license usb key on mac. ?
regards
Regnar Rabe
Yes, Macs are using standard USB components and the MADRIX KEY will also work there. The Windows OS will then have the correct drivers for the stick when installing MADRIX.
Regnar
Post by Regnar »
hello Again
thanks for your answers.
Final question: what Windows version is most stabil ?
regards
Regnar Rabe
Hello Regnar,
Regarding the performance and stability we recommend Windows 7.
But if you are buying a new PC with the lates hardware componets you should use Windows 10.
Because this hardware components will only supported in full performance with Windows 10.
