Madrix Ignores I.P. address of Philips Hue Hub
danozfw
Post by danozfw »
I am trying to use Madrix to control Philips Hue Bulbs but Madrix will not recognize my Generation 2 HUE hub. I have verified that the computer running Madrix and the Hue Hub are on the same network. When I launch Madrix I can see in the status bar on the bottom of the program that Madrix is scanning the network for devices. At one point I see that it has found the I.P. address of the HUE Hub but there is a statement at the beginning of the line. "ignore: IP 192.168.1.44(the Hue IP). Any help would be appreciated.
Re: Madrix Ignores I.P. address of Philips Hue Hub
Hello danozfw,
For a detailed issue analysis we are in need of a MADRIX logfile. Can you please send a logfile to info[at]madrix[dot]com
To save the logfile please perform the following steps:
1.) Connect the Hue Bridge to the MADRIX PC
2.) Try to find and authorize the bridge like described in the following link:
http://help.madrix.com/m3/html/madrix/i ... s_hue.html
3.) In MADRIX, go to "Tools > Logfile", click the button "Save As..." and enter a name for the Logfile.
Hello danozfw,
We found the reason of the explained issue.
This issue should be fixed with one of the next software updates and you can use "Philips - Hue" lights generation 2.
danozfw
Post by danozfw »
I just downloaded 3.6c and it seems there has been some progress. Madrix will now find my Hue Gen 2 Bridge but it will not authorize the Bridge. I will send the Log File to the above listed address. I am aware that this will be fixed in version 3.7.
Regards
Hello danozfw,
Thank you for reporting the issue.
We found the bug. The bugfix will be available in the next release of MADRIX.
MADRIX 3.6d is now available for you!
