Effect Parameter Chaser - Not Exporting Correctly
lrueda
Post by lrueda »
I created a multi-step effect parameter chaser that displays correctly on the preview left/right and the preview output, but is not transmitting correctly to the LEDs. LEDs are running in approximately 30 universes off of 4 Nebulas. The other effects are all transmitting correctly, and the wiring and patch have all been tested and confirmed.
Are there any known issues with the parameter chaser, or fixes to what is occurring?
Re: Effect Parameter Chaser - Not Exporting Correctly
Thank you for your report!
Could you please send all the details, including a description of what is not transmitted correctly to the LEDs, the MADRIX Setup file, as well as a Logfile to info[at]madrix.com?
We'll have a look and will make sure to get back to you.
Thank you very much!
