Recording Cue Lists to Plexus
mstrkrft69
Post by mstrkrft69 »
is there a way to load a cue list straight into the Plexus? it looks like i have to play the cue list and record it in real time. is that right? so if i have a cue list that is hours long do i have to do it in real time? also, when i record my cue list and check the box to play off of the 1st cue, my cue list keeps looping repeatedly so i cant just get the single run through the cue list recorded, even though my list isnt set to loop. thanks.
Re: Recording Cue Lists to Plexus
Thank you for your questions!
1) Unfortunately, there is no way to load a cue list straight into the PLEXUS. (That would mean that the PLEXUS generates effects in real-time, but only a computer with the MADRIX software can do that, while the PLEXUS is a playback solution).
2) Yes, you would have to record the cue list in real time.
3) Thanks for letting us know! We are going to double-check this. To solve this for now, you can edit the record after recording and could cut any single frames that are too much in the Recording window of MADRIX.
