Nebula stand alone
Nebula stand alone
Hi, is it possible to use the matrix Nebula stand alone, setting the device before use and without a pc in the location?
Thanks for help.
Thanks for help.
Re: Nebula stand alone
Hello claudio,
The NEBULA is a live interface. That means it is not possible to use it in stand-alone without another Art-Net sender.
If you need only two universes (340 RGB pixels) output, an option could be to us a MADRIX PLEXUS as Art-Net sender. The PLEXUS now will send the saved effects to the NEBULA via Art-Net.
If you will need more than two universes output I would recommend to use a PC with MADRIX or another console to send the Art-Net data to the NEBULA.
Also two or more PLEXUS can serve together a higher amount of DMX universes. In that case the PLEXUS devices communicate inbetween each other by the network to synchronize.
