Madrix midi control keyboard cue wise
DJDNL
Post by DJDNL »
Dear all,
Happy holidays!
I want to control Cue's with my keyboard. So by example, cue 1 (storage place 1) assigning with 1 button of a midi keyboard. I know how to assign midi control and everything works, only i cant find this solution.
prob to simple but i hope someone can help me.
Best regards
Re: Madrix midi control keyboard cue wise
Hello DJDNL,
It is possible to use a MIDI Keyboard for the described tasks in MADRIX.
Therefor you need to create your own MIDI map.
Under the following link you can learn how you can create an own MIDI map:
http://help.madrix.com/tutorials/html/i ... i_map.html
I think your issue was that you don't have changed the Max value for the desired command. If you want to activate Storage Place 1 with the desired MIDI command the Max value must be 0, if you want to activate Storage Place 2 the Max value must be 1 and so on.
