Trivial issue Plexus -> DMX512
expolight
Post by expolight »
we have issue with
http://www.ebay.com/itm/Led-controller- ... 1030527145
We connected normal RGB strip to this DMX driver
connect plexus via USB and connect Plexus and dmx512 driver 3ch via 5pin DMX cable
In madrix we
- enable Plexus and check output
- set Fixture igeneric! rgb
set Plexus
but Plexus didn't recive DMX. => DMX no data.
Where is problem?
remote options - recive via DMX on port DMX 1 - start channel 1 - DMX ->art-net on
Maybe we set plexus wrong or
Maybe we forgot something?
Need we some fixtures like electron-design fixture to contol normal RGB strip?
Thank you :-)
Re: Trivial issue Plexus -> DMX512
I would first advise to disable the 'Remote Options'. This could already be the cause. Please only activate these settings if you wish to control the PLEXUS unit remotely from an external source, but right now you wish to output DMX data on the ports instead of receiving data.
Does that help?
