madrix key on network
lightman
Post by lightman »
hello, is it possible to have a key on a local network an share the madrix key to connect a second madrix on another pc for backup ?
thanks
Re: madrix key on network
Hello lightman,
In MADRIX 3 it is not possible to share the licenses via network between different PCs or between a network USB hub and the PCs.
If you will use a backup system, both PCs needs a MADRIX KEY.
