Configure remote control?
aristocompasso
Post by aristocompasso »
Hi all,
Is it possible to configure what shows up and how in the http remote control?
If not, how easy or difficult is it to interface the remote control with another application?
Thanks.
All the best!
Re: Configure remote control?
Hello aristocompasso,
It is possible to see the preview of the left and right side of MADRIX in the HTTP user interface. It is also possible to view the thumbnails of all storage places in the HTTP user interface.
The best way to test is to enable the HTTP server in MADRIX and have a look to the preprogrammed user interfaces. There you will find one which shows the previews of MADRIX. Under the following link you can learn how you can enable the HTTP server in MADRIX:
http://help.madrix.com/m3/html/madrix/i ... _http.html
If you want to create your own HTTP user interface, you have easiely create a HTML page with the functions you will find under "MADRIX Remote Members".
aristocompasso
Hi Guertler, thanks for your reply.
I have already looked at the public html remote files and it looks easy to create my own custom html page, which is great!
But I ran into another problem and the manual doesn't seem to help.
"Connect to the web server using the remote control device.
- Often, this will mean that you will use a web browser on the remote control device."
Is it possible to use another application to access the http remote control? I am trying with Unity and it doesn't seem to work. Connection always fails for given IP Address and Port number.
All the best!
It should be no problem to send the HTTP command with another application as a web browser when the application sends the HTTP command in the right format.
Have you tried to open the HTTP webpage of MADRIX on the device which was not working with "Unity"? Or does a firewall block the HTTP command?
