Ableton Push 2
bez
Ableton Push 2
Post by bez »
I've successfully routed MIDI from the Ableton Push 2 through Ableton Live into Madrix. Figured out how to do so by watching "How to control lights with MIDI notes to DMX using Ableton Live & Freestyler DMX " on Youtube.
I'm not a MIDI expert, but I assume that the MIDI code originating from the Push is passed to Madrix, and then it needs to be interpreted. In the Madrix Device Manager I see there are many options for MIDI Remote Controls. Is the Ableton Push going to be added to this list?
I'm currently using the demo of the tool and I'm blown away, and can't wait to get a license key when I have the funds.
Re: Ableton Push 2
Hello bez,
Thank you for the input.
At the moment there is no predefined MIDI map for the "Ableton - Push 2". When you want to use it in MADRIX, you can easily create your own MIDI map. Under the following link you can learn how you can create one:
http://help.madrix.com/tutorials/html/i ... i_map.html
bez
Re: Ableton Push 2
Post by bez »
Thanks Guertler!
