Possible to run Madrix with a Windows Tablet
Randyw57
Post by Randyw57 »
Is it possible to run Madrix with a windows Tablet instead of a stand-alone PC
Re: Possible to run Madrix with a Windows Tablet
Hello Randyw57,
You can use a "Windows Tablet" to run MADRIX on it. Of course it depends on the desired patch size if the performance of the "Windows Tablet" will be sufficient for the job.
But MADRIX will not run on a "Windows RT". You have to use a "Windows Tablet" with "Intel" or "AMD" chips.
Hello mikasa,
If the Windows Tablet is equipped with Hardware components accroding to the MADRIX System Requirements, you can also use it.
More about the MADRIX System Requirements you will find under the following link:
https://help.madrix.com/m5/html/madrix/ ... ments.html
