Effect Parameter Chaser fading times
alf130386
Post by alf130386 »
Good day! I added some cues to Effect Parameter Chaser with different effect directions and colors within SCE Gradient. I set fading time for each cue, but they are playing without fading. Is it possible to use fading on direction change in Effect Parameter Chaser? Thanks
Re: Effect Parameter Chaser fading times
Hello alf130386,
The "Fade Time" of the "Effect Parameter Chaser" will only work in case of you are changing settings which are assigned to a Fader in two different steps. If you are changing settings which are assigned to buttons in MADRIX, it will not fade equals which "Fade Time" is set.
