MIDI console and audio slider / audio number value
I think have found a bug in to MADRIX.
I control MADRIX with a MIDI controller.
If changing the audio level via MIDI , the slider changed but the number value bottom the slider do not changed. I need this value to check my current level. the number is better than slider.
The slider works fine, only the numbers not correct.
The neighbor slider changed the number value if it change via MIDI.
Thats why I think it is a BUG.
Re: MIDI console and audio slider / audio number value
Hi dieter,
ok i checked it inside our office and yes unfortunately i have to say you are right the value in the edit do not change if modified by midi.
We will fix this in the next release.
Thanks for bug report!
