Patch fixture rotation on x and y axis.
Irwin
Post by Irwin »
Hello, I'd like to see the ability in the patch to rotate fixtures on the x and y axis, not just on the z axis. Thank you!
Re: Patch fixture rotation on x and y axis.
Hello Irwin,
At the moment MADRIX provides only the possibility to rotate on the Z axis. If you want to rotate a fixture on the X or Y axis, you will need to create the fixture in the desired rotation with the help of the Fixture Editor.
Under the following link you can learn more about the MADRIX Fixture Editor:
