how to use Madrix to control addressable rgbw led strip?
Aliya Li
Post by Aliya Li »
We got the problem to control addressable rgbw led strip, such as sk6812rgbw and ucs2904 rgbw led strip. how it make it work with rgbw 4 channels ? does it need any controller when using madrix to control?
Re: how to use Madrix to control addressable rgbw led strip?
Hello Aliya Li,
When you want to control digitial LED stripes with MADRIX, you will also need an additional Art-Net to SPI controller like the MADRIX NEBULA. With one MADRIX NEBULA you will be able to control up to 1360 RGB pixels. If you will need to control more pixels/LEDs, you can connect more NEBULAs to the MADRIX PC.
Under the follwoing link you can learn more about the NEBULA:
https://www.madrix.com/products/nebula
