Using Timer to Control Plexus Extension Port
cinetron
Post by cinetron »
I am having trouble getting a Timer to trigger the control of an Extension Port. For my example I am using Port7 . I set it to a digital Output. I have no problem controlling the Port using Scene as an Action when using a Timer but if I try to use Port7 as an Action with a Timer it doesn't work. I see when the Timer is triggered on the Plexus display but if I look at the status of the port or measure the pin it hasn't changed. Wondering what I could be doing wrong when using Port# as an Action to control the Extension Port or could this be a bug. I am using the latest firmware.
cinetron
Re: Using Timer to Control Plexus Extension Port
Post by cinetron »
Still looking for some guidance on what I could be doing wrong here.
Hi there!
Could you please send us the full PLEXUS Configuration files to info[at]madrix.com, which you can export using the PLEXUS Configuration window in the MADRIX Software.
Thank you very much!
