Use DMX-Commands
madamx
Use DMX-Commands
Post by madamx »
Hi guys,
We have LED DMX-Lights which can controlled via the normal DMX-Protocol. But we also have implemented other commands which can control for example the brightness of the Lights (without the need to calculate it on the RGB-Values). This allows us to achieve a much better variety of colors.
These special commands start with another startbyte and then send the command specific data. Is there a way that we can use our special commands in Madrix?
Thank;
Re: Use DMX-Commands
Hello madamx,
MADRIX is working according to the DMX standard for DMX controlled lights.So it is hard to implement other commands to contol the brightness. Of course if it is DMX based you can control it. But not other specific fixture based protocols are supported.
The supported color managment of MADRIX 3 is based on RGB(W) color mixing.
