SCE video information is missing
kaneko@lasens.com
Post by kaneko@lasens.com »
Hi, I would like to ask someone about SCE video between 2 PC.
1. Setting SCE video effect of PC "A"
2. Save file
3. Open the same file at PC "B" (the video file exist both PC A and PC B with same directry
4.Video setting is missing even the name.....
Is it possible this kind of problem will be solved???
cf. Here is the my Madrix project with 240 univerces.
https://www.14dd5266c70789bdc806364df4586335-gdprlock/watch?v=YARsH8Z0V7Q
Re: SCE video information is missing
Hello kaneko@lasens.com,
Please double check the location where the video file is stored again . If you have stored the video for instance under the prepared "Videos" folder in Windows, this loction is user based and often you are working on every PC under other user names.
When you want to work with a MADRIX setup which includes videos on several PC I would recommend to save the videos everytime in a folder under "C:\" for instance "C:\media" and copy this media folder to the other PC.
kaneko@lasens.com
Mr Guertler,
Thank you for your reply.
And OK, I will store "C:\media" by now.
under the "media" folder, can I make other folders for specific project?
thank you in advance..
When you want to work with subfolders on your PC in the office , you will need to create the same part of the folder structure also on the PC which is located at the project. For example you create on your PC in the office a structure like:
"C:\media\project1", "C:\media\project2" and so on. Now you are creating the setup for project one and all videos are located in "C:\media\project1" you will need to create the same folder structure ("C:\media\project1") at the PC which is located at the project.
