ASIO Discussion Thread
Lysenberg25
Post by Lysenberg25 »
Hello All,
We are quite excited about the Madrix 5 launch that has come out. Everything seems smoother, and simpler. Any good information on ASIO AUDIO would be great. In the manual;it explains the set-up it pretty well. However, how can I determine if the Sound Card on the computer is capable of doing ASIO, etc.?
Any information provided will be greatly appreciated. Thanks to everyone over in Deutschland for making the best pixel software / hardware solutions in the market.
-FDI
Re: ASIO Discussion Thread
Hello Lysenberg25,
The information if your desired sound card is able to work with ASIO you will find in the manual of the sound card or at the website of the sound card.
ASIO means Audio Stream Input/Output. If the sound card supports it, you can receive the audio stream with ASIO in MADRIX. If not, you have to use the WDM driver to receive the audio stream in MADRIX.
Lysenberg25
Thank you for your reply. I truly appreciate it.
Lysenberg25
Guertler wrote: Tue Sep 11, 2018 1:54 pm Hello Lysenberg25,
Thanks, Guertler*
We may have found a bug. Will update soon.
