Potential ASIO Bug
Lysenberg25
Potential ASIO Bug
Post by Lysenberg25 »
Hello All,
We may have found a bug in the ASIO Audio settings.
When the ordeal is done, it saves at times, and at times the settings do not.
Potential bug, or user error? The PC is capable of ASIO.
Thanks for any info in advance.
Re: Potential ASIO Bug
Hello Lysenberg25,
Can you please tell us some more information when it will work and when not? Do you disconnect the soundcard in between?
Can you also please tell us the MADRIX version you are using. You will find the exact MADRIX version in the Menu under "Help > About".
Lysenberg25
Issue has been resolved. It was an issue that intermittent.
It wouldn't save settings, and was resolved with simple driver update.
It was at initial launch of, Madrix 5.0, on the 25th of the 5th month. 2018.
Thank you for your reply. Pardon my latency.
You may close the thread, cheers!
