I need more time to code ?
Re: I need more time to code ?
Hello vincitytaymodaimo,
Both options are possible. You can receive SMPTE time code with MADRIX or trigger MADRIX with the Hog 3.
To receive the SMPTE time code in MADRIX you will need the MADRIX SMPTE interface. Under the following link you can find some more information about the SMPTE interface:
https://www.madrix.com/products/i-o
Please scroll down a bit.
In the following tutorial you can learn how you can work with time code in MADRIX:
http://help.madrix.com/tutorials/html/i ... nd_du.html
When you want to control remotely with the Hog, you will have several options to control it. You can use DMX Input, Art-Net Input or sACN Input in MADRIX.
Under the following links you can learn how to trigger MADRIX via DMX and Art-Net:
http://help.madrix.com/tutorials/html/i ... mx_in.html
http://help.madrix.com/tutorials/html/i ... emote.html
