Does the DEMO output any DMZ instructions?
GRIFFCOMM
Post by GRIFFCOMM »
Hi
I was tasked with testing Madrix against Pharos, so i have a DEMO of Madrix installed (version 5). We have a test DMXKing ePro 1, the DMXKing talks with the fixture (the DMXKing software has a test environment and it pushes commands over DMX so the fixture changes).
Its a static IP address on ArtNET 1 (0x0000), Madrix finds the ePro with the correct IP address it has listed ArtNET 0x0000 and shows it as universe 1 as output, however no matter what we do in Madrix i cant get ANY light output, nothing is going through the DMXKing, so does the Madrix demo actually push anything?
Typo above, should be DMX (been working on DMZ most of the day)
Many Thanks
Ashley
© Copyright 2018 - www.griffcomm.ca
Re: Does the DEMO output any DMZ instructions?
Hello GRIFFCOMM,
The Demo Version of MADRIX 5 will not output any data to the connected Art-Net node. To unlock the output of MADRIX 5 you will need a least a MADRIX 5 KEY start.
